B
bahco
right lads need a bit of advice which seems to be a bit of a grey area among the sparks ive spoke to.
ok so tncs pme supply, from consumer unit via 32a 100ma rcbo to garge about 20 mtrs away fed it 6mm 3c swa, in the garage 3 way metalclad board 63a rcd main switch 2 circuits, lighting 6a sockets 32a final ring
now the confusing bit, im led to belive you cannot use the earthing system in your house to earth your garage.... reason is your garage is not in the same equipotential zone as your house.
so would i need to install a earth rod for the garage or is it ok as it is?
any help or advice would be great
thanks lads
thanks lads
