- Joined
- Jan 13, 2010
- Messages
- 231
- Reaction score
- 76
Hey folks
Im currently working on a large individual domestic property which is also a new build.
Just wanted to get a few opinions if possible.
The electricity meter and main fuse (PME earth system) are installed in a large outbuilding beside the main house. The outbuilding is to be used as a kind of plant room where there will be a ground source heat pump, rain water pump and few other bits n bobs. The pipework between the plant room and the main house is plastic. The incoming water main to the property is in plastic. No other incoming services.
I want to export the PME earth from the plant room/outbuilding to the main house. I intend to feed the house from an 80amp switch fuse. Ive worked out the loadings and this should be fine.
I cant see any problem with this but would really appreciate others views on this. Mainly on the export of PME in this situation.
Many thanks in advance
