C
claret73
Have been asked to look at adding an extra alarm for a customer as building control have told them they require an extra fitting. (I think they are renting out the house).Have done some Googling about & reading through my Aico Handybook, so have come up with this:
The Smokes are on their own circuit, hard wired, interconnected. They are Aico manufactured, so will replace 1 base unit with a Radiolink (quick thought, Would I still need to connect the Interconnect core, from 3 core cable to maintain a link from the previous feed? This unit is the 2nd in the radial circuit). For the additional unit, I'll fit a complete radiolink, which will sync with the existing hard wired, now replaced to Radiolink unit. The feed for this will be fed off an existing light point (closest is a Spot, will break in with a JB and spur to the Radiolink base)
As far as BS 5839 Part 6 goes, can I download a suitable certificate FOC? & would this require a Minor Works cert under Part P? Or is this classed as an additional lighting point - IE Coming off the Spot to feed the Radiolink base?
I'm not Part P, so if that's a Yes or I can't sign the Smoke Cert I'll pass it to my Contractor.
Cheers for any info
Cheers for any info
