extending a ring | on ElectriciansForums
Discuss extending a ring in the Australia area at ElectriciansForums.net
M
maddog2010
hi could any body please help me whats the best way to extend a ring main in to a conservatory im haveing a few problems thankyou
Run 2 2.5mm T&E cables from existing socket in a ring round your new socket(s)
Disconnect 1 cable from existing socket and crimp 1 new cable onto it in backbox. Connect your other new cable into existing socket with other original cable.
Extending a ring main
As per advise given by sintra
Extension to a ring main ( If loading is not an issue )
For more than 1 double socket,
Fit a fused spur at source and add on until your hearts content
You need a specific tool and the crimps I would not recommend the DIY crimper for about a ÂŁ1
What is the actual problem we may have abetter answer for you
Chris
cheers chris i have wired a conservatory up with a ring main and in the up stairs bedroom i have ripped floor boards up drilled out threw cavity wall and dropped cabbles down in to concervatory and they have now been dry lined plasterd over. how i was gonna wire it up was in the floor space up stairs in the bedroom i was gunna brake in too the ring and youse two jbs but the cable i cut and fort was the ring was a 3core and earth must be for the lights switchs down stairs so now my cables are short to go to a socket, the 3 core and earth cabel i cut i have put back together with a chocky block :(
sorry acat i was sending the reply too you aswell
Sorry bud but you should'nt use a choc block or junction box under floorboards as it won't be easily accessable in the future, use crimps or wago boxes and when crimping use a heavy duty ratchet crimper not the flimsy one for a couple of quid;)
As above by monkeyelectric the crimper you will need to buy will cost ÂŁ15-ÂŁ30 depending on where you go just make sure its the ratchet type. Google the wago boxes if you are not sure what they are.
Best of luck
Chris
is this true just out of interest, i understand not using choc blocks but isnt a junction box okay, ie if you spliced into a ring between two sockets for a spur. i can see the point of view of it not being accessible though. just bringing it up cause i've seen i done plenty in past. not by me of course :rolleyes:
They can be used but should'nt be as if there was a fault you can't get to them easily without ripping up carpet an floorboards or even worse laminate flooring, any screw terminal must be accessible, thats why maintenance free joints must be used such as crimps or wago boxes;)
Reply to extending a ring in the Australia area at ElectriciansForums.net
But why do they want a CU? That won't give them any more available power than they currently have. As it is a 2.5mm SWA cable it is presumably a...
davesparks
If it's going to be an emergency stop and not just a stop, then other factors come into play depending on what sort of machines the emergency stop...
