Hi all. I would like to ask a question about extending the cables when moving a consumer unit. Is it acceptable to use an adaptable box with the correct size through crimps and heat shrink within the box? If this is acceptable then would this box need to be accessible or not as I would be using an appropriate compression tool (ratchet crimper)?. Thanks
