T
timo
Heyup
Need to bond a gas meter thats around 1.5 to 2 Metres away from the water stop tap. The water is done in 10mm already so i was thinking if i solder or crimp and extend to gas meter aswell will this comply as i know if you do both the cable shouldnt be broken but if i crimp/solder the existing cable is in theory one pice and not 2. What do you guys think on this.
