Extending Lighting | on ElectriciansForums
Discuss Extending Lighting in the Australia area at ElectriciansForums.net
R
rantoftheday
I want to extend a lighting circuit for an extension
The current system is loop in live
Can I take a feed from one of the ceiling roses to a junction box and run all wires to the three new rooms to there?
Compromising of 16 x 50watt downlights plus 1 extractor fan
Yes you could do that, or you could take the feed down to the switch and join the neutral there, saving having to have a junction box.
Some people don't like doing it that way, but IMO it's the best way in this situation.
Would safely say lads there are halogen ....................and a waste of time.
some of the LEDs are well good now malcolm, iv'e never rated cfl's though
My next door neighbour when I was home put some LED ones in his kitchen to be honest Tel the warm white ones made you look jaundice and the bright ones were a little bluish, I think they are an acquired taste.
But I have to be fair Tel, I think by now everyone knows my take on "downlights" so I may be biased.
Reply to Extending Lighting in the Australia area at ElectriciansForums.net
I would use the Switch & Load 16A - https://www.quickwire.co.uk/product/switch-load-16a/ Designed to do the same thing as the ceiling rose in...
An extra joint box isn’t a massive issue… use a wago box, with proper wagos. Nice and small will fit up through downlight hole. Wago box should...
