E
Engineer54
What Spin has stated, is to a greater extent correct, the DNO fuse is primarily there to protect the DNO equipment and installation. Can it also protect the householders installation, Yes, but is a coincidental bonus that is typically made use of in domestic installations. It has been argued for years now, that all installations (including domestic) should be provided with it's own main protective device. Possibilities are suitable DP MCB/MCCB within the CU, or a DP Switch fuse. The problem comes when you try to get a degree of discrimination between the DNO fuse(s) and the downstream protective device...
