Extending/Moving Ceiling Rose/Pendant between floor joists ? | on ElectriciansForums
Discuss Extending/Moving Ceiling Rose/Pendant between floor joists ? in the UK Electrical Forum area at ElectriciansForums.net
Birmingham
Hi All.
I need to extend the cables for a 3 plate ceiling rose/pendant on ground floor ceiling by 450mm. Can I fix the ceiling rose/pendant to the ceiling joist and then run 3 core 0.75mm flex through the plasterboard ceiling to the light fitting. Or, do I have to extend all three 1.5mm T&E cables in MF junction box, and then connect 3 core 0.75mm flex out of ceiling to light fitting ?
Unfortunately all the rooms haves laminate flooring, except the one where I have access.
Any advice will be kindly appreciated.
  • [ElectriciansForums.net] Extending/Moving Ceiling Rose/Pendant between floor joists ?
Reply to Extending/Moving Ceiling Rose/Pendant between floor joists ? in the UK Electrical Forum area at ElectriciansForums.net
Definitely looks like the cpc (earth) has been sleeved and used as a neutral conductor, this is not permitted. You are going to need an...
