sg spark
Hi have just extended a ring main,am i correct in thinking that i have to test the complete circuit and give customer an e.i.c or do i issue a minor works and just test the extended circuit ?
Discuss extending ring main in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Minor works if your alteration or addition is to one existing circuit only...no matter how extensive the alteration.
The only thing with a M/W is there is no provision for recording end to end ring readings...you should still test these,and the results could be recorded in the comments on the existing box.
there is on the certs i use.Minor works if your alteration or addition is to one existing circuit only...no matter how extensive the alteration.
Trouble is you need a lot more info to complete an EIC......being of a lazy persuasion when it comes to paperwork if I can get away with a MW then I will.Hence why I would use an EIC
There's not on the NIC ones....there is on the certs i use.
Reply to extending ring main in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
