Extending table lamp flex | on ElectriciansForums
Discuss Extending table lamp flex in the DIY Electrical Advice area at ElectriciansForums.net
Scotland
I have a table lamp fitted with 2 core 0.75mm flex.
I wish to extend the length of the cable but only have 2 core 1.5mm flex to hand.
Can I use this, or must the flex be the same diameter both sides of the join.
Sorry if this is a ridiculous question.
Thank you for your advice.
You can use flex that's a larger size than the original but it would be better to replace the entire flex rather than trying to make a joint mid-length.
Thank you Marvo. I’m swapping out the switch for a WiFi switch and the existing cable length isn’t sufficient to reach the power socket.
How are you planning to extend this cord.
The existing cord is 0.75mm with a switch midway through it. Was planning to remove the switch, leave the 0.75mm going into the lamp, replace the switch and have a metre of 1.5mm from the switch to the plug.
Yeah, as Tel says, good luck getting the 1.5mm cable into the switch.....
It would probably be a lot less heartache in the long run to buy some .75 flex.
Haha thanks @telectrix ! Good point about the size of the cut out in the switch.
just amazed to hear that you have electric light in Scotland. thought you got light from a peat fire with a hole in the roof to let the smoke out.. :D:D:D.
[ElectriciansForums.net] Extending table lamp flex
Reply to Extending table lamp flex in the DIY Electrical Advice area at ElectriciansForums.net
I would use the Switch & Load 16A - https://www.quickwire.co.uk/product/switch-load-16a/ Designed to do the same thing as the ceiling rose in...
Sounds more positive.
