extension cord thru ceiling going in attic ? | on ElectriciansForums
Discuss extension cord thru ceiling going in attic ? in the UK Electrical Forum area at ElectriciansForums.net
ktnwin
San Jose, CA
I like to be able to connect an electrical tool such as small vacuum cleaner to clean things on the attic or a light.
For convenience, I like to plug one end of this cord to an outlet on the ground level, then let it run straight up to a small hole on the ceiling to the attic. So, only a few feet of this cord will be below the ceiling, the remaining will be on the attic.
I ONLY plug this cord in the outlet when I am about to go up the attic to do some work (usually less than 40 mins).
When done, I unplug the cord from the outlet. This way, the cord on the attic has no electricity. To be even safer, I could put install a timer outlet so electricity will be cut off after a set time (45 mins for example).
My question: does this scenario violate NEC code ?
Not 100% sure about code violations, however it is a tried and tested method all around the world.
I would not recommend a timer on it though, the risk of being stranded in the dark when the timer runs out is far greater than accidentally leaving it on for a while.
I do not worry about the light goes off due to time-out. My wife always hang around when I go in the attic, she can reset the timer every 30 min. On top of that, I have a head lamp (+ one extra), the power is mainly for other things (hand held vac, drill, etc..), the cordless version of these tools may not be strong enough.
As already been said don’t add a timer because you will be walking a fine line of code violations. The only thing I can think of as far as the code book there is no mention of what your doing except adding a Sleeve to protect your drop cord. Just keep doing what your doing and do not alter any electrical devices and you will be fine
If a timer outlet is a code violation, I WON'T DO IT. I like to stick to the NEC code.
Reply to extension cord thru ceiling going in attic ? in the UK Electrical Forum area at ElectriciansForums.net
Not familiar with american regs but in the UK the factor that limits the length of power cords is the resistance of the earth lead, over certain...
