Extension lead length | on ElectriciansForums
Discuss Extension lead length in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
G
gdrms
I've seen many cheap(ÂŁ1.49) 4 way 0.5 metre extensions on sale in Asda and Morrisons. I seem to remember from somewhere that an extension lead has to be at least 1 metre long. Occasionaly, the short cable allows easy placement for audio etc. but I thought it wasn't allowed. Does anyone else remember this or am I mistaken and going senile?
I just had a quick look through the code of practice and found the bit about max 25m (2.5mm) with rcd over that length, but nothing about minimum length.
Volt drop would be a limiting factor for max length. This varies according to the load so wouldn't it come under the general cable size regs?
SHORT !! You don't get any shorter extention lead than a mains adaptor !! Just a cube - but its still treated and tested as an extension lead !!
Reply to Extension lead length in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
