Extension | on ElectriciansForums
Discuss Extension in the Australia area at ElectriciansForums.net
G
gibbyisking
Hi guys,
I am currently doing an extension which involves 4no. new circuits. I am running them back to the existing mains board. I have to change the D.B to a bigger one so it can house these new circuits. The existing board is a 10way split load board and I will be installing a 15way dual split load board.
What I am wondering is will i have to test the whole house or just my new circuits?
test your new circuits and the new CU. i find it's best in these situations to test the whole installation. you then end up with a respectable schedule of test results, instead of a load of N/A s.
I agree with Tel, test the old as well as the new - who knows, it might just save your life. At the very least you'd be testing it all within the next nine years anyway, right??!
Reply to Extension in the Australia area at ElectriciansForums.net
Good point, they do look a bit 6mm-ish when you mention it, and that is not going to last long enough for a D63 to trip! It might, on a good day...
Thank you for the speedy response! Have seen them on top of plaster in steel conduit before but guess it's not a common desire to have wires...
