Extention Lead Cable | on ElectriciansForums
Discuss Extention Lead Cable in the DIY Electrical Advice area at ElectriciansForums.net
N
Networkline
Extention
Which cable do I have to use for electrical extention ?
1.5 or 2.5 ?
Hi,
I've made your post into a thread of its own, it was off-topic in the place you posted it.
I'm guessing from the little info that he's built and extension on his house and wants to use a trailing lead....:)
From the title I thought he wanted to make am extension lead ?
A 1.5mm² cable will be sufficient for a normal extension lead, rated up to 13A (the maximum size of a BS1363 plug fuse).
A 2.5mm² cable is too large to safely fit in a normal domestic plug and should not be used in such.
I don't think we will ever know as he is not replying . Maybe tomorrow !
My first guess was he had a lead-sheathed cable and was going to extend it by making a wiped joint.
Lead sheathed cable proves to be a devil to wind back up,on me 30 meter drum....but i'd arm wrestle shrek afterwards:stooge_curly:
Reply to Extention Lead Cable in the DIY Electrical Advice area at ElectriciansForums.net
hi....im running cable for a split type 1.5 hp aircon....i have a roll of english 2.5 twin & earth, is this ok for the job? im running it to the...
It's a room where someone sleeps, so it's a bedroom. Minimum standards were set in the Parker Morris report in around 1963. Anything built after...
