exterior light | on ElectriciansForums
Discuss exterior light in the UK Electrical Forum area at ElectriciansForums.net
neath
quick question
installing exterior light power coming from downstairs socket spur.cable coming through wall and up to light on exterior wall
Do i need to place cable in conduit /trunking or can i clip direct to wall ? without mechanical protection
cheers scott
if you want to clip direct a short run up the outside wall to light i'd recommed fp200 cable , it clips neater than t&e.
pvc conduit is better but can be a pain to connect into the bottom of some types of decorative light
not unless you consider it to be at risk from damage. personally, i'd use 20mm pvc conduit throgh wall and up to a IP 55 adaptable box adjacent to the light, then black flex from box to light. both cable entries at the bottom of the box.
Reply to exterior light in the UK Electrical Forum area at ElectriciansForums.net
That was my saying not long ago about TNS to PME system. I would be nice you can ring up the DNO, will the systems being up graded, there is a...
Better off with the click prw213 as it has twin screw termination.
