Hello. I need an outdoor socket and bought a ‘kit’ that allows a ‘soft wire’ IP66 socket. It is connected inside through the wall to an indoor socket by flex and a captive RCD plug. Unfortunately they sent a ‘hardwired’ unit which costs more but leaves no trailing leads inside. So I’d like to make use of it BUT ... being hardwired I would take a fused spurs off an existing socket on a Ring Circuit and connect the outside socket to that (IP66 grommets included).
However, whilst the ‘soft-wire’ option complies with regs as it is essentially an extension cable through the wall, I am aware that the hard wired unit may well need certification. Please someone confirm either way so that I can either return for the soft wired unit or go ahead with a hard wire install. As you have guessed I have electrical competence but as a diy-er. Thanks
