G
goldie
Hi all.
Customer has asked if I can mount light fitting on top of an existing pole to illuminate a section of a car park.
There is power local to the pole already and there is a pir sensor bolted to it which energises another light remote from the pole.
Only problem is that the pole is shorter than what we need.
I did recommend a lampost to replace the existing pole, with either an LED head at the top or a twin flood.
Anyway client is on a budget etc etc.
Does anybody know of a collar bracket that can be strapped to existing pole and a light which can be attached? flood or lantern will do.
Thanks in advance
Thanks in advance
