External lighting fault | Page 2 | on ElectriciansForums
Discuss External lighting fault in the UK Electrical Forum area at ElectriciansForums.net
London
Fault on external lighting roughly 12 lights around a building, RCBO tripping, my tester only goes to 200 Megger Ohms
L-N is 0 Megger
N-E is greater than 200 Megger
L-E is greater than 200 Megger
LN-E is 150 Megger
Now tested insulation from board and roughly found the middle light with 1 cable so must be joint boxes somewhere I can’t find, went to a light further and found a joint box and tested each leg and was getting near to no Megger Ohms on each side, any further ideas?
I ap
i first do a continuity test L-N to see if there are any loads connected. sometimes there may be a neon switch will read something like 23K ohms. ( or is it 2.3 K, i forget, bloody dementia)
all loads are still connected they all have emergency back up too, so L-N I’m getting 0, have done LN-E and getting over range, all I can do is take the rest of fitting apart and bypass all circuitry or go to one in middle and re test there but will possibly give me same readings
Reply to External lighting fault in the UK Electrical Forum area at ElectriciansForums.net
It is actually specified in BS7671 that the cpcs must be connected to all other sources of earth.
When you did the further testing and got the 0.06 reading were the CPC's back in the consumer unit? Really when testing you should leave the...
