Hello all,
I know this is very simple but I would like some advice please.
I am installing a new circuit to feed 5 external floodlights.
It is to be controlled by a digital timer with volt free contacts through a 2 pole contactor wired with the existing photocell which also does a couple circuits with external lights.
There will also be a 20A DP switch with a neon indicator to over ride the circuit for testing purposes during daylight.
The way I would wire it is my feed from C10 RCBO to top of contactor. Then the bottom of my contactor will go out to my floodlights.
Now this is the part I am getting confused with. I need to take a feed from the existing control circuit to feed my new timer/contactor. Am I right in saying Permanent Line to my time clock then link to the common of time clock and then N/O to my contactor coil A1. I will also take the existing photocell A1 from another contactor to my contactor. I will then take the L out from the 20A DP switch to A1 of my contactor. The only issue is that there is already an existing override switch for another external lighting circuit so when that is switched surely it will backfeed to my 20A DP switch.
I can’t think of how to prevent this. Any help will be greatly appreciated.
