M
Murdy
Evening all,
When wiring multiple external lights to operate on a single switch is the following ok when you havent the room to pull the loop into the light fitting ?
Pull light loop into the switch box and wire on one side of the switch.
Take switch live out of the switch to first lighting point.
link the lights from the first lighting point.
Neutrals are joined in the switch box using connector block.
Is this the neatest way ?
