Hi,
New to the forum but fairly competent DIY enthusiast.
I have recently moved into a house which already has an external circuit in the basement (protected by a circuit breaker, max load 40a) powering 4 external double sockets, this is run off the main RCD protected circuit board for the house.
I also have a currently unpowered detached garage about 30m from my house which I'd like to run power too, just a simple tube light and a couple of sockets for a small heater and general power tool usage, possibly some basic gym equipment in future. I am also about to start building a pond so would like another double socket in the garden about 15m from the house to run a UV pond filter and pump.
So, my question is - can I simply run an external fused spur off one of the existing sockets that can power both the pond requirements and then a spur from that socket running to the garage? Do I need another fused switch after the socket in the garage to run to the light switch?
Planning to do all outdoor power runs in SWA clipped to fence.
Is the above acceptable, or could you give me a better way of doing things?
Thanks, in advance!
Thanks, in advance!
