Hi all,
I have been asked by a company that installs sewage systems to have a look at some recommendations from another sparks who has looked at one of their jobs. I haven't visited the job, but I have seen a few of their installations in the past and he has me at a bit of a loss. The plant is apparently connected into a commando socket in a small waterproof housing with the pump, near to the septic tank. This is run in SWA back to an external spur on the side of the house, fed from an existing socket which is on an RCD protected circuit.
A sparks has inspected the property and told the customer that the SWA should be seperated and an earth rod installed because "PME Supply must not be used for outdoor wiring due to the risk of the incoming neutral being open circuit."
Can anyone shed any light on this, or send me some reg numbers to look up? It seems like massive overkill as there are no extraneous conductive parts that this could affect.
