hi there guys,
just wanting bit of advice if you don't mind.
iv never had to install a meter before so be kind
iv been asked by a local business to fit an external socket. which isn't a problem.
the external socket is for a different business - a catering van and they want to charge the catering van for the amount of electricity they use.
the 3phase board is only 3 meters at the most from the wall they want the external socket.
was thinking- breaker from the board to an 2 pole isolator to the meter (either normal or prepay) then to socket.
isolator and meter will be in a cabinet out side on the wall.
by cable cals i'll only need 2.5mm
but can you use 2.5mm for the meter?
any advice would be grateful
