extract fans | on ElectriciansForums
Discuss extract fans in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
When an isolating device is installed remotely from the equipment it is meant to isolate, the device must be able to be locked in the OFF position. 537.2.1.5.
So if the 2 fans are not in the same location as the isolating switch then it has to be lockable.
Bear in mind if you get a fault on one of the fans and it needs to be isolated you loose both fans not just the faulty one, i would always install a seperate isolator for each fan, the extra time involed and price of isolator is minimal.
thanks for the advice. i think i will spur off one and use a 2nd isolator on the other as this is a toilet and a shower room that are not in the same location so hope this will be ok ?
Reply to extract fans in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The 2 inputs are separate and there should be no interlinking between SL1 and2 If there is there has to be a wiring error or a fault with the...
Hello, this comes late (new) and likely you would fret remodeling, but as a TIP for the general public then: Where a ceiling fan, can likewise go...
