extract fans | on ElectriciansForums
Guest viewing is limited
Discuss extract fans in the Australia area at ElectriciansForums.net
keniff
east sussex
does anyone know if what im saying is correct, if a bathroom or anywhere that needs an extract fan has natural light the fan does not need to switch on with the light, if the room has no natural light the fan HAS to activate with the light. i cant remember but was having a convo with another spark today
if the bathroom has natural light and the fan is supplied from lighting circuit then it doent need an isolator.
if no natural light then it does ;)
hope ive interpreted your question right :eek:
think you may find that the fan requires a means of isolation even if it does have natural light as most fans these days have a permernat feed so this needs as you are aware isolating and also if you are replacing the fan rather than isolate the complete lighting circuit which may have dark area it can be isolated locally ,also stops little mrs jones switching the light on when you are working on it ,need more light my dear if you see what i mean, the question regarding the light and switch where a bathroom has natural light i will install a movement sensor , this way the fan can operate when its light or dark
have to disagree there nick :p will back it up with a reg when i can be arsed to move ;)
top of page 62 egbr until i find my red book :eek:
My age old question
Why would you want a ventilation system controlled by the intensity or lack of light :confused:
Is it not better to control a ventilation system with regard to when its necessary to extract the air :cool:
My age old question
If the room had no natural light you would nearly always turn on the light upon entering, whereas someone might not necessarily turn on the fan, thereby effectively making the pullcord an occupancy switch. The fan is not just to remove excess moisture but smells as well; as far as I know there isn't currently a sensor available that can distinguish between air freshener and undesirable body aroma.
Reply to extract fans in the Australia area at ElectriciansForums.net
The 2 inputs are separate and there should be no interlinking between SL1 and2 If there is there has to be a wiring error or a fault with the...
Interesting document thanks. But it neglects the half-wave rectification, and also totally neglects the effect of the coil inductance when...
2 3
Recommended Sponsor News
Hi everyone,
