I've never done anything with extraction fans but I've got a job coming up where the customer wants to remove pull cord for extractor fan and pull cord for light and put into a 2 gang wall mounted light switch.
The light switch would be 1.2m away from the edge of the bath. The extractor fan is a cieling mounted fan and they plan to keep this. The fan is above a walk in shower.
I don't know yet if the fan is mains or 24v.
Many questions on this job as I've not seen it yet but my first question is, is it acceptable for an extractor to switched via a light switch? Is there a reg that states a fan isolator switch is needed? If so can the fan be switch via a wall mounted switch and also a local fan isolator?
