Hi all,
My flat's kitchen has an integrated extractor hood currently setup as a recirculator. Above this on the ceiling but slightly offset from the extractor hood is an axial fan connected to ducting to exterior wall via about 3-4m of ducting with 2 90 degree bends. I'm thinking of changing the setup either to just replace the ceiling axial fan for a centrifugal and leave the hood extractor as is to remove smells. Or I could take out the axial ceiling fan completely and connect the hood extractor straight to the ceiling ducting. One downside to this is that the ducting from the hood to the ceiling will be visible above the kitchen cupboards and as I say it will have to bend a little to account for the offset of the hood outlet and the ceiling duct entry. The second issue is that the initial vertical duct section will be 80cm or so before turning 90 degrees, is this an issue?
It's currently a bit of a mixed setup and seems a shame not to make the hood extract if the ducting is there! Would appreciate any advice on this.
