Extractor Fan in Downstairs Loo | on ElectriciansForums
Discuss Extractor Fan in Downstairs Loo in the UK Electrical Forum area at ElectriciansForums.net
Kent
Hi Folks,
I've been asked to install an extractor fan in a downstairs toilet .
One that sits in the glass of the window. (That part has been done already)
I'm going to look at the job tomorrow so I'm assuming the window is just the glass and doesn't actually open hence the need for the extractor fan?
Will this need an isolator switch outside the toilet, as if it were being installed in a bathroom? Or can it just have it's own pull chord inside?
Is there a MUST for these to be timed units or can it come on and off with the light switch?
Will it need to have a FCU?
Just need clarification on these points as all I can see in the regs in installations in special locations. Although there's a strong possibility that I'm looking in the wrong place!
As always, feedback and help is greatly appreciated.
Most regs regarding extraction fans apply directly to brand new builds. Been ages since I have browsed through all the building regs but I’m sure extraction is all included in there...
Just out of curiosity:
I'm presuming you replace the glass with wood or something, that the fan sits in??? Or do you cut a big hole in the glass??
Doesn't the cable going to these fans look rubbish, if it's on show?
Yes, the fans that fit in glass always look rubbish.
You actually fit it in the glass? Wasn't sure if the vibration of the fan would cause the glass to crack over time..
@Spoon I have no idea about the installation in to the glass, this has already been completed but yeah, j agree it looks horrible imo!
Not being a domestic guy I was just curious as to how they do it. Love to learn things new.
One thing to bear in mind is that the manufacturer's instructions may stipulate a 3A fuse in the feed.
Which can be ignored as manufacturers instructions are guidance only. The fan should have built in protection, any fuse is to protect the cable, not the fan. The cable fitted to comply with regs must be bigger than rated at 3a. Finally this stipulation cannot be followed in other countries where FCUs are not available nor compliant.
Reply to Extractor Fan in Downstairs Loo in the UK Electrical Forum area at ElectriciansForums.net
I think you are going to need an electrician because it looks like someone has used the bare earth (has been sleeved black) as a live conductor...
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
