extractor fan just humming | on ElectriciansForums
Discuss extractor fan just humming in the Commercial Electrical Advice area at ElectriciansForums.net
C
chopperxbox
My friend has a restaurant and the kitchen extractor fan has stopped working but when you turn it on it just hums. It's a 450v 12 inch inline extractor. I changed the capacitor for a new one and still the same. It's about 9 years old and 6 months ago he had it cleaned out. He said they jet washed it. It's there anything else I could try or does he just need a new one. Any help or advice is appreciated. Thanks.
IR test the motor and continuity test the two windings assuming single phase motor. Just out of interest why on earth would anyone jet wash a motor and expect it ever to run again?
The OP mentioned it was 450v and it had a capacitor, think you are right mate single phase for sure, for the OP have you got the voltage right, the rotor ain't jammed solid with rust is it?
Yeah, I was also confused by the voltage stated, it's a very odd supply voltage, then I thought the 450v probably refers to the discharge voltage written on the capacitor. If the motor has a capacitor then it's 99.99% certain it's single phase. Also it's only 12 inches diameter so it's basically a domestic fan by the sounds of it.
Reply to extractor fan just humming in the Commercial Electrical Advice area at ElectriciansForums.net
Thanks for your advice guys. very helpful
Thank you. We do have a window. Do you think my idea (even if is adds complexity) is workable? Nothing fundamentally wrong that I am missing?
