I haven't seen many fans fused to 3 amps myself even if it is the right thing to do, the vast majority are wired straight off the bathroom light to a triple pole fan isolator and then back to the fan and work off the bathroom light when energised, unless there is a large window in the room working off the light rather than a PIR would be more realistic for the consumer, if you can add a 3 amp fuse somewhere then go for it, if not I wouldn't worry too much about it myself, but the manufactures may not honour the guarantee if it packs up.
