extractor fans in kitchens | on ElectriciansForums
Discuss extractor fans in kitchens in the Australia area at ElectriciansForums.net
B
blenki
Hi , my sister is having a new kitchen fitted soon and i am doing the wiring for it , id just like to check if an extractor fan must be fitted that vents to the outside air , as it stands im not sure on the situation.cheers
hi building regs approved document F states mechanical extract 30 litres above or within 300mm
or 60 litres elswhere basicly you can vent your hob extract to the outside or
fit a 6 inch fan
Agree with old dog.
It should vent to outside air, although it does not have to be the extractor hood over the cooker.
It can be elsewhere in the room but has to have a higher extraction rate, as pointed out.:)
But as this is a new kitchen and not a new build then he can fit what he likes, and Mr building controll can whistle.:)
i done a job new kitchen x council flat client did not want an extract fan building control refused to sign it
off this was not a new build i think the bco was whistling as he left now that you mention it
mr building control cant go and whistle cos of part p, new build or not. kitchens like bathrooms are special location so ALL work must be tested and registered, unless you wanna run the risk
Reply to extractor fans in kitchens in the Australia area at ElectriciansForums.net
Hi all, I'm looking for recommendations for a kitchen extractor fan with a rate of 60l/s. We're nearly done with our renovation, but we've just...
dimmi1975
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
