I am buliding a porch on my house and i'm going to make half of it into a drying room, so i want an extractor fan with a humidistat so when wet stuff in there drys and creates humidity inside the humid air is expelled via the fan.
as it's a drying room heat loss is an issue, so when the fan isn't needed it wants to be as sealed up as possible, and i know from experiance that one anti backdraft shutter and a venitian blind style vent flap is not going to do a good job an a windy day and it will lose alot of heat, sooooooooo i've heard you can buy fans with electronically controlled louvre vents that are normally closed and then open when the fan is signalled to run, this seems like an ideal solution as they wouldn't flap and bang in the wind and lose heat.
anybody know where i can find one? or is it possible to buy the vent as a seperate part, so i could choose whatever fan i want and then connect the vent to it.
