Extractor fans | on ElectriciansForums
Guest viewing is limited
Discuss Extractor fans in the Australia area at ElectriciansForums.net
C
Cj24
On a fan isolator you have a 3 core go to it cus you need a sw a perm feed and neutural am I right? Then a 3 core out to fan, well assuming I am right does this mean you can only wire off the first light of a circuit because that's where your perm feed goes into your loop and if you go off last fitting you only have a sw feed
yes we know that but you stated "does this mean you can only wire off the first light of a circuit " and the answer is no.
you can wire off anything you want providing you have a live and neut and in your case also a switched live for extractor.
If u have 2 ceiling roses in same room only one of them will have perm feed at it
er no, depends how its wired
i can see where you coming from, but your question is badly worded.
Reply to Extractor fans in the Australia area at ElectriciansForums.net
I think you are going to need an electrician because it looks like someone has used the bare earth (has been sleeved black) as a live conductor...
as mentioned by Westward a link is the way forward, nothing wrong with that and the pull cord will then be the on off switch.
Recommended Sponsor News
Hi everyone,
