Theres a bathroom that I've been asked to do some work on. It's an old bedroom that is being changed into a bathroom. Amongst over things an extractor fan i going to need to be installed but theres a slight problem...there is actually no way to get ducting outside! The floor above which is the top floor is chipboard with laminate flooring on top of it, the walls in the bathroom have steel re-inforcements behind the plasterboard. From inside the bathroom to outside it goes plasterboard-timber-steel-block work and this is a ridicuous width! The windows also can not open at all for some reason! First time I've ever come across a problem like this and was just wondering if theres any way around it ie having the correct ventilation to comply with regulations?
