Discuss Extraneous conductive part in external workshop in the UK Electrical Forum area at ElectriciansForums.net
I wondered the same, whether they are essentially roof beams, or part of a larger steel structure that could introduce a potential.That looks like a steel support rather than a Columb (which would go into the ground).
I suspect the roof is more likely to be extraneous. Odd structure with the wood beams supporting it, a barn?
Not done any testing on the Steel yet… noted on a MWC …@ the moment they are not bonded.I wondered the same, whether they are essentially roof beams, or part of a larger steel structure that could introduce a potential.
I was trying to decide if they are bolts at the end, suggesting there is a steel super-structure....
That’s a good point if MBPC required could be feasible to bond @ one point at steel ceiling I guessI wondered the same, whether they are essentially roof beams, or part of a larger steel structure that could introduce a potential.
Good point… no inter connection between the 2 though…ceiling & steel’sI suspect the roof is more likely to be extraneous. Odd structure with the wood beams supporting it, a barn?
Steels are into the groundI wondered the same, whether they are essentially roof beams, or part of a larger steel structure that could introduce a potential.
Reply to Extraneous conductive part in external workshop in the UK Electrical Forum area at ElectriciansForums.net
