'f ' connectors | on ElectriciansForums
Discuss 'f ' connectors in the Australia area at ElectriciansForums.net
M
miner69er
hi everybody
hope someone out there might have a bit of advice for me. i need to extend/split a tv cable to go into a customers extension, it's the f type screw on connector, is there anything odd about this stuff or is it nearly the same as extending a normal tv cable?
Reply to 'f ' connectors in the Australia area at ElectriciansForums.net
Thanks a lot for the quick reply. I already have a good number of the 32A single gang connectors so I'll be using those on each individual wire...
Try to use a catenary wire for better support for your outdoor cable. I'd recommend TP-Link ceiling-mounted access points, which are good options...
    • Winner
