Failed EICR Query | Page 5 | on ElectriciansForums
Discuss Failed EICR Query in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You'll never cover every inch of the country with mobile data. The law of diminishing returns prevents that. Jimmy in his cottage on the edge of the Outer Hebrides will always struggle.
But that's by the by, as you say any data will be uploaded when signal is available.
I still don't see how you are going to agree all these details though. You will have to go through everything with the tenant/customer each time.
I get the idea of the technology side of things, and I do think it could have some useful input don't get me wrong.
No offence but you guys really know very little about the tech that is coming, and this thread proves it.
Wait until you hear about what they're planning with drones. Neuron | Hedera Hashgraph - https://hedera.com/users/neuron
Genuinely no offence meant.
In what year will 5G offer mobile data to every inch of the UK? Genuine question.
EE want to do it by 2028.
So in an ideal world it might happen in 7 years. And targets like this normally slip, so most likely longer. 'At some point it may happen'. No doubt 6G will be well under development by then.
But, as I say, we're digressing. Any data just gets uploaded whenever there is a suitable signal.
Let's get back to EICRs. We definitely need a way of clamping down on them, and I think spot checks are a good starting point. Random to start with, and then targeted once patterns are seen.
Do you know how the proposed 5g networks work? They can literally cover every square inch of the planet if they need to.
I know a property which is in a built up area on top of a hill it has line of site to a number of masts which I know have the necessary connectivity but you cannot get a mobile phone signal it doesn't make any difference whether it is 2g, 3g or 4g even a smart meter is dead in the water and I can't see 5g being any better
There has been talk of high speed internet across the whole of Wales using radio links for many years to my knowledge large areas of Wales are still waiting for it to happen
You appear to be well up on technology so you will know how many years this has been in the pipeline
Indeed. It sounds similar to many of the targets touted by various companies over recent decades. Not just tech companies, but automotive and energy companies too.
Well yeah but this is all missing the point. You not being able to get a signal at some cottage in Cumbria or on the Scottish Islands doesn't mean tech won't be used to literally collect data on everything you do in the next 5-10 years.
That tech can (and probably will) be leveraged to ensure electricians are doing compliant work. My example was just a 'back of the smoke packet' suggestion. Someone much smarter than me will come up with a much better way of doing it, but the point is, just like smart meters can collect data without you doing anything, this tech can be used without the end user even knowing it's being used.
In the very near future you will be able to digitally sell partial quantities of fixed quantity physical items without ever touching the actual physical item. Coming up with something for EICR's is a piece of cake for those who understand how to implement this tech.
If anyone wants an insight, i'd suggest reading some of Siemens' whitepapers, especially those detailing their roadmap for the next 30 years, in particular their stuff around smart homes and smart cities, and also check out what Google, IBM, DLA Piper, Wipro, Shinhan Bank and the London School of Economics are up to.
So you are already backtracking on 5g covering every inch of the planet
Smart meters can't even communcate properly in some built up areas so the tech has limitations
Implementing the tech is one thing whether it is of any use is another as data protection will be involved in what is stored and no doubt there may be client issues
So the pie in the sky blue sky thinking, the servers of today are already chewing through many megawatts now will we have enough electricity to run all this in 30 years
Nope, was pointing out that the point wasn't even that. 5g WILL cover every inch of the planet. But that's not relevant to the point i was making and is a pointless side argument i'm not interested in having.
Sorry but you should stick to electric since you have no clue about technology. No offence meant, genuinely, but you sound just like the pre boomers who said the internet would never take off - you don't know how much you don't know. For instance you would never make the point about data protection if you actually knew the immutable data can be stored anonymously via TLS encryption.
OK so none of us has any idea of technology, you will have your app which will record everything in every square mm of the planet.
How will it determine the issue or non issue - there is a 4mm hole in the consumer unit - what does the app do?
How does it get this information and what happens?
Do you decide C1, C2, C3, or nothing?
If so how is the technology fixing the problem?
You are just throwing technical terms around without any real substance. TLS is an encryption system which has been around for many years. It has no real relevance to your argument.
You are also changing your arguments as you go once things are pointed out to you, and you avoid some points which are put to you.
Repeating the word 'immutable' endlessly does not increase the relevance of your point.
Having said that, I agree that technology could be used more to improve things. But so could spot checks, and as UNG says, more control over who can actually perform EICRs.
This debate seems to be going the same way as the one about advising a newly qualified electrician to do notifiable work and tell the customer that they could just not bother notifying it if they preferred though.
The app wouldn't do that, i said 5g would be everywhere eventually.
It would rely on user input.
That's for a regulatory body to decide.
I don't know why you're expecting me to come up with some full working solution. It can be done, trust me, but if i had the time to sit and work it out i wouldn't be following a Level 2 college course and would instead be getting tech firms and venture capitalists on board.
Eventually technology will render this stuff impossible to fake. And it's just around the corner. Yes it could be done via an app integrated with a tester, it could be integrated via thermal imaging technology, it could be integrated by smart contracts where the customer and engineer have to agree beforehand what condition the installation is in making it impossible for someone to, say, drill a 4mm hole and claim it was there to begin with, or clip out some cables and claim they need rewiring etc.
It's theoretically possible to actually install a ledger straight into an installation which means you could read and record cable values etc without even going to the building. It would just send data like a smart meter does.
It's also possible through a range of technologies to prevent stuff from being tampered with without it being recorded somewhere.
You guys will get how big this stuff is going to be in 5-10 years when we have billions of drones flying above head, self-driving cars, self-managing smart cities, full smart homes and flying cars (no, i'm not joking) and robots delivering our mail (no, i'm also not joking, check out SingularityNET.)
Until then my best guess is that it would be prudent to have some sort of central authority responsible for EICR's, and it would be possible to install a simple interface that records all the data straight from the MFT to a cert - i know you can get torque wrenches that connect to software and send the reading directly to a cert. All you have to do is connect that data through an immutable public ledger and the result cannot be changed - if the tested read 1ohm it records 1ohm and you cannot say it didn't since the ledger is immutable. The possibilities are endless.
Yeah only i never said that did i? Don't you remember, we went through this. You simply twisted my words because you cannot properly infer implicit meaning. I challenged you to provide evidence where i said anything like what you claimed i did and you melted away like a wet rag because you know full well i didn't say it. 'Well, we all KNOW what you MEANT'. Yeah sure. Simple case of you getting it wrong and then compounding your error by refusing to back down and admit you were wrong in order to avoid looking silly. Very dishonourable.
Reply to Failed EICR Query in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Merry Xmas to all :D
As the cable itself has had the cpc cut off at both ends I would enter a C3 as it doesn't offer any protection within the cable if accidentally...
He said something about a fused something as the lights hardly take anything .. I told him was mostly cordless tools so just chargers ..told him...
