fan control | on ElectriciansForums
Discuss fan control in the Australia area at ElectriciansForums.net
benji
north east
One fan to extract 2 bathrooms, switched from both bathrooms
what are the options.
yours benji
This isnt always the wisest way to do bathrooms but if you do then an inline fan and both bathrooms will require some form of backdraft shutter or actuators to close them off when extraction not on and the piping will need to be designed as not to allow circulating currents between bathrooms when fan is off, if you do 2 seperate fans with 1 common ducting then get a fan that has closing shutters on it so the other fan cant circulate air into opposite bathroom
Reply to fan control in the Australia area at ElectriciansForums.net
Whats it doing ? It can be hard to see the need for all this smart control of basic items The smartest control is probably when the fan does its...
The tighter rules came in around June 2022. I think you summed it up nicely. My understanding is that a competent electrician could install...
