fan isolation connection units | on ElectriciansForums
Discuss fan isolation connection units in the UK Electrical Forum area at ElectriciansForums.net
England
hi guys, apologies. I've tried searching here as been discussed before (upteen times).I did inquire before and received very good advice including pics of item.
I'm after isolation switches for extractor fans. The isolation switches will go in the loft space. Many of you recommended a click? type switch which just pull apart for isolation of fan. i require them for L+N+Sw. Thanks
possibly, ive been trying to look for click
This is the 4 pin ..... I believe they do a single plate type socket as well as this besa one.
[ElectriciansForums.net] fan isolation connection units
Out of interest why do you want to use this?
To keep the bathroom lights /fan installation neat as being switched outside the bathroom I didn't want to see the 3 pole isolation switch. So after a great discussion on here, I decided to go for Greenwood fans as no 3 amp fuse required. Many electricians on here use the Klick connection so as to isolate the fan re maintenance. Hopefully that is the product, if not something very similar.
I'm still puzzled - sure the Greenwood fans make sense but why not a standard 3 pole fan isolation switch! The click connector that people refer to is the connector that HandySparks linked to!
Reply to fan isolation connection units in the UK Electrical Forum area at ElectriciansForums.net
Hi Richard, thanks for your comment. The relay is rated 12A peak. It's also worth noting that a relay contact will perform differently depending...
    • Winner
