Fan isolator switch... | on ElectriciansForums
Discuss Fan isolator switch... in the Australia area at ElectriciansForums.net
J
jimjamyaha
Hi,
We've had an extractor fan wired into our bathroom by an electrician. However he's put the 3-pole isolator next to the fan.
The fan is a timed/humidistat one that is triggered on by the light and then runs on it's own.
The fan and the switch are in zone 3 - but I understand that isolator switches for the fan should really be outside of the bathroom.
He's certified the work with a certificate - should I get him back to sort it out, or is it ok to be left?
Thanks,
James.
Personally, I would have positioned the isolator outside of the bathroom, however, since it is in zone 3 (or outside of zones as per 17th edition), there is nothing in the regs to say that it can't go there.
Reply to Fan isolator switch... in the Australia area at ElectriciansForums.net
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
I recommend the Manrose Humidistat timer: Humidity Sensors for fans -...
