Hi rapid, if theres a fault on the circuit sure, what would expect, if and you havent told us, is there a fault somewhere, is the fan faulty or is it connected properly.
i put a fused rcd spur connecting 12v bathroom lighting witch was fine didnt trip but when i connected the fan it kept triping the rcd but if i connected it not through the rcd it worked fine?
