Farm solar problem | on ElectriciansForums
Discuss Farm solar problem in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
gaz101
Devon
Been asked existing customer to look at what solar experts
Are fitting up
50kva from shed roofs to farm meater
Conected from load side of main switch then PVC enclosure whith rcd,s & mcb,s
all look,s ok
Also 4 kva from farm shed roof in PVC t&e through sheds then over head to
house house is on its Own supply
Thinking that when farm main switch is off there will still be mains in sheds
what do you think ?
Reply to Farm solar problem in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
You should have no problems with what you want but even if you install conduit the cable still needs to be UF cable which is approved for under...
