farm supplies. | on ElectriciansForums
Discuss farm supplies. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
South east
having read on other posts about people having split phase farm supplies, id like to be educated as to what they are, and why they exist.
:D
basically a centre tapped secondary winding gives you 2 hot legs and a neutral/earth - for USA thats 120-0-120 for Uk thats 230-0-230
or for site work(reduced low-voltage) 55-0-55
i think the economics are that that when the loads are balanced on the two hot legs -the neutral current is zero and the 2 hot legs carry half the current of an equivalent 2-wire SP supply
Reply to farm supplies. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Your kWh figures are giving you consumption averaged over each hour period, but don't give an indication of total instantaneous current. To try...
If the shared neutral is lost ,won`t you be getting 400v across both cottages? 2 phase US style but double the Voltage.
