DurhamSparky
New Area for me this...
Basically i have fitted a 3P&N 100A Switch Isolator to a supply from NEDL
next step is approximately 100m run in 35MM 4 core swa buried from Service position to a 3phase DB..
my intention is to then fit a secondary "local" isolation point with intergrated fuse links as to not have to rely on the DNO cut out fuses some distance away..!
from this Switch Fuse position im in to a 3phase 8 way Db with 100A 300ma rcd for overall protection. with socket outlets been further reduced to 30ma
then its down to individual circuits each ran at height in black pvc conduit to individual outlets apart from a 3phase corn dryer which will be powered by 5core swa and a manual change over switch position for operation of main/gennerator
have i missed any thing...? ideally whole install would be in SWA but not my decision...!
