Fault current | on ElectriciansForums
Discuss Fault current in the UK Electrical Forum area at ElectriciansForums.net
Diib I now that lol just been working out thermal constraints on my design protect and noticing the lower the zs the higher the fault current was wondering if anyone could explain why other than ohms law
Hey, think basic maths.....230V/23ohms = 10amps...... 230V/230ohms = 1 amp, notice that the larger the figure you divide by, the lower the answer..its really that simple .....ohms law;)
So if are zs are to good ie a very low impedance surely are high fault current could possibly be dangerous
You're looking at this from completely the wrong direction, if there's a L-E fault you want a low earth impedance for two reasons, firstly to prevent the chassis of fittings and appliances developing high touch voltages which could cause someone to get a fatal shock, secondly a low earth impedance means a very large fault current flows which in turn means the OCPD disconnects the faulty circuit very quickly.
Reply to Fault current in the UK Electrical Forum area at ElectriciansForums.net
https://sravivarman.com/technical-articles/parallel-operation-of-thyristors/ Series resistor, or bigger series resistor, needed?
Not to mention welding switch contacts together and wondering why when they thought they had got the wiring sussed the light will still not switch...
