Fault finding- AM2S. What is the pass mark for AM2s fault finding | on ElectriciansForums
Discuss Fault finding- AM2S. What is the pass mark for AM2s fault finding in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
That's what they told me when I did my AM2 as long as everything else is fine (if you fail the safe isolation then that's an instant fail regardless of how many faults you identify correctly)
Upvote 0
Reply to Fault finding- AM2S. What is the pass mark for AM2s fault finding in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Great, then I am a bit bemused why you posted your original question. You need to stop doing any work that you cannot properly test, safety is...
When I did my AM2, I had it drummed into me that I had to follow Guidance Note 3 carefully. So, did you follow the guidance in GN3 for checking...
Electrical Courses
