you on about your practical in college or the am2?
in college they not that hard just try and keep a cool head i remember mine i made a few silly mistakes like forgetting to place the sign on the padlock
anyway your fualts will virtually be easy to find just go through your normal testing procedure example r1 and r2 you may come across an open circuit
insulation resistance you may come across a short and you will also have visual fualts that basically stand out like a sore thumb example you will have a cracked light fitting or the safety sign on the bonding missing
also remember the biggest reason for failing is not placing the key in your pocket after safe isolation
