My confidence levels and ability levels have increased hugely in the past year. In others words I have gone from knowing 0.1% of all there is to know about electrics to around 1.5%!!
I would just like to gain more confidence and knowledge regarding ‘tripping RCD’s’!
I have only changed one CU and it went smoothly but throughout the change and afterwards I did not feel confident, solely because I was fearful of one of the RCD’s tripping when all connected and not being able to solve the problem. So I will not change another one until I have a better understanding of ‘How to find the fault of a tripping RCD’. I did a prework survey which included a satisfactory IR test between live conductors and CPC but maybe next time it wont be satisfactory and I will need to fault find before proceeding.
I guess I would really like to know these 3 things:
2. How do I narrow down the search? Finding the circuit at fault should be straightforward but how do I locate where on the circuit the fault is (i.e on a ring/radial or lights), how do I narrow it down?
3. Any other tips on fault finding?
I know this is a pretty lame question, but I'd rather look a bit daft and know the answer!
Cheers guys..
- How to use my clamp meter (has earth fault capability) to detect earth fault. Is it as simple as clamping on relevant earth and reading? What results should I see? Any reading greater than 30mA? Would this residual reading only show if the circuit was live? If so how can you get a reading if its always tripping?
Cheers guys..
