E
electromonkey
Afternoon all
I am testerless for a few days and have encountered a problem that I would like to fix today. I'm sure it's something obvious that I've missed so if I run this set up by one and all someone I am sure will suggest something that I have over looked, I hope.
Loft lights on their own circuit. The order of the circuit is as follows WALK IN WARDROBE (2 lamps) ---- LANDING (2lamps)-----BATHROOM (4 lamps-feed to fused spur for shaver)------BEDROOM (6 lamps). I have LED GU10 Down lights only on the circuit. All the lights are working fine with the exception of the landing lights, which when I switch off at the switch run very dimly with my continuity testers not picking up any voltage???
I've checked all the connections and removed the feed to the shaver spur.
Does anyone have any suggestions as to what may be causing this fault? I'm thinking it's a neutral fault but then don't understand why the rest of the circuit isn't effected.
Cheers
Cheers
